So I installed A New Ragjoint And...
derek7871
Post by derek7871 »
Now my 3 on the tree is acting funny. After I got the rag joint in I took it for a spin. The steering is much improved, but I'm having a hard time changing gears. They're not grinding, just kind of hard to shift them. In fact, in third gear and turning left, the steering wheel/column actually got a hold of the shifter somehow and knocked it out of gear. Did I tweek the shift linkages when I slid the column back to change the rag joint? Any ideas?
'68 F-100, 360, 3 on the tree, manual steering.
Cooter
72stepside
re: So I installed A New Ragjoint And...
Post by 72stepside »
Sounds like one of the alignment studs is grabbing your shift arms at the end of the tube. :?
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
ezernut9mm
Post by ezernut9mm »
how are your cab mounts?
derek7871
Post by derek7871 »
My cab mounts are in fair shape. Not perfect, but not not bad enough to let the cab sag down. I was thinking last night that I may have the steering column a little higher or lower than before, and that's causing the shift linkages to bind up.
Cooter
if the cab sags at all it will put pressure on the rag joint and related items. why do you say your column mihgt be higher or lower than before?
ezernut9mm
that's why i was asking. any cab sag can cause binding.
derek7871
Post by derek7871 »
I didn't really mean the column was higher or lower. You know how you have to pull the wheel and column into the cab to change the rag joint? That's what I meant. Anyway, I think I found the problem. Just above the ragjoint there is a little clip (not sure what to call it) that screws together to hold it tight on the steering column. I did not have that clip up high enough. I guess it holds the shift linkages in line? Shifting in the driveway and driving in the yard feels ok. I'm taking it out on the road in a few minutes and make sure it's ok.
Cooter
