How to pull a windshield?
Anyone know an easy way to pull a windshield? I have the chrome trim on the rubber which I want to save so next question, is how to pull trim?, then, how to pull windshield. This one is cracked so I really don't care what shape it is in when it comes out. Ideas appreciated.
1967 F100 LWB
1972 F100 SWB 4x4
Assorted Harleys
1972 F100 SWB 4x4
Assorted Harleys
- 69twotone
re: How to pull a windshield?
I pulled one not long ago it is still sitting in my basement. The trim can be gently worked out by hand either using a screwdriver with some sort of padding between the screwdriver and the trim. You just have to go really slowly. Once the trim is off you can just cut the windshield rubber and pull it out. Make sure you have someone on the inside so the window does not fall in and break.
I am not sure how to get it out without cutting the rubber. I am sure there is a way that a professional windshield installer might know of. You could try some sort of hooked tool which is padded and bend the rubber up or have someone on the inside gradually apply pressure as you bend the rubber up. The one I pulled was on a scrap truck so I did not care about the rubber.
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
If your rubber is not any good you can cut it from the inside with the knife like Keiths other thread says from the inside. Then its a lot easier to take the chrome out.
Foggy
Foggy
- slamons
Salmons i have found if the rubber is still good take a flat blade screw driver and push the inside lip down and push it back beyond the cab lip.
Foggy
Foggy
well if you want to save the rubber, and the glass is already cracked
I would just kick the glass out. but cover you face, and protect the hood.
remember that rubber gasket cost more than the glass.
WHAT ?
It takes a little longer but a lot safer to take a flat blade screw driver and push the rubber behind the metal lip.
Foggy
Foggy
