Cab Removal the easy way
heres how we did it today since dad has a wrecker we just lifted it off.
69twotone
re: Cab Removal the easy way
Post by 69twotone »
Hi Fordman,
That really is the easy way. I am debating replacing my cab since the original floor is gone. It has sheet metal patches so there aren't any holes right now. I keep thinking it would be a huge job. You sure make it look easy. 8)
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
i was lucky i usually just tip the cab off one side and let it fall off the frame. but thats a junk cab. i havent ever removed a good cab until now.
Yep, that's exactly how I did mine a few times:
The last time I talked my wife's father into using his boom truck:
MadMaxetc
Post by MadMaxetc »
You guys are lazy...
Dan
FORD Girl
Photobucket Pictures
MadMaxetc
Post by MadMaxetc »
Whooo Hooo!! 4 stars!
Dan
FORD Girl
kaptnkaos
Post by kaptnkaos »
Hey Dan,
Congrats on yer new star !!!
KaptnKA 8) S
The_Eman
Post by The_Eman »
As my kids would say, ok, and me sometimes too or maybe alot. NO FAIR... :cry:
FLATBEDFORD
Post by FLATBEDFORD »
Here's the come along method. Don't use this method if you're keeping the cab.
Chain across the front of the bed. Come along to chain. I hooked the cable to the firewall and cranked it on.
Steve
My Photo Gallery
MaxKlinger
Post by MaxKlinger »
Ok, so supposing I DON'T have a front end loader, crane, etc, and I want to keep my cab and use it again, what is the best way to remove it? What are the things I need to disconnect from the frame and at the firewall?
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
MadMaxetc
Re: re: Cab Removal the easy way
Post by MadMaxetc »
MaxKlinger wrote:Ok, so supposing I DON'T have a front end loader, crane, etc, and I want to keep my cab and use it again, what is the best way to remove it? What are the things I need to disconnect from the frame and at the firewall?
Disconect ALL brake Lines, Electrical Lines, Front Fenders, Steering Column, 4 Cab Bolts.
Roll the windows down or remove the doors. Stick a 4x4 through the top of that cab and use and engine hoist to lift it off the frame.
Be carefull not to nock the hoist off the 4x4 or it will go through your roof!!
Dan
FORD Girl
71Ford100
Post by 71Ford100 »
And here I was hoping to see a torch.
Max. I used a chain hoist to remove the cab on my '71. Just find a good sturdy beam or two fab something up to support the hoist, get a 2x6 4x4 sometihng heavy and thick, fab up a sling and presto redneck cab remover.
Lance Peters
FLATBEDFORD
You could also invite a bunch of friends over for beer, pizza, and cab lifting. :wink:
Steve
My Photo Gallery
MaxKlinger
FLATBEDFORD wrote:You could also invite a bunch of friends over for beer, pizza, and cab lifting. :wink:
That's typically how I get things done, although most of my high school wrenching buddies have moved away now. So when the time comes...what kind of beer do you like, Steve?
Tony
FLATBEDFORD
Get Rhinelander for best results. Good luck finding it around here. Ask two-bit where to find it. You don't have to bribe me, just give me good warning so I can make the time. I do however like sausage pizza.
Steve
My Photo Gallery
