lower fender bolts
lower fender bolts
Anybody have pics of the lower bolt on the fender that somehow mounts it to under the cab or whatever? I can't figure out how they went, and it doesnt look like theres a hole anywhere?
- flyboy2610
You have to get at it through the opening in the door where the lower hinge is located.
- flyboy2610
Oops. I was thinking of the wrong bolt.
Never mind.
Never mind.
- 1971ford
re: lower fender bolts
thanks for the pics, looks like mine are broken. I have the bolt and clip........with nothing for the clip to go onto. Wonder how I am going to fix that. maybe I can get that bolt and bracket off, weld a little piece of steel on there and put it back together.
yea that what i would do is to make a new bracket onto the bottom of the cab drill a new holes and put a new bolt and clip back on it. as far as that long winded bolt in the door nige area i was thinking of drilling a hole thought the kick plate so i could get at it better. and then use a plastic rubber type of body plug to cover the hole i drilled. does that sound like a good plan?
well, i wish i could get my extension and 3 bolts back from that dang door bolt setup!!!
- 1971ford
sounds good. i would do it myself but that bolt isnt vvery necessary. i took off the door button for the dome light so i could get my hand in there but it was still extremely hard especially because that u nut was moving with the bolt! so i just didnt tighten them down. i tried shaking the fender by where the bolt would go and it was stiff in place. i had some casualties when i was trying to tighten that bolt down with a ratchet - a few bolts and one or two sockets fell down and i could not get them.
if you do drill the whole i would like to see some pictures. so if i ever did it i could get some idea.
-Ryan
That's a good idea, I may do that this afternoon as they REALLY need to be bolted down. I loops some zip ties in the bottom because I plan on getting new fenders. Don't want to weld that up and it not be where it should with the new sheet metal. It's probably a 5/8 hole, since the socket is 1/2 inch. might even need to be 3/4 hole.....
