Hood Letters?
JWW
Hood Letters?
Post by JWW »
I recently removed my hood from my 67. I'm planning to replace it with a hood from a 69. I'm a little confused because I read that the 67-69 hood letters are the same. See pic below from "Identifying '67-'72 Pickups":
However, the letters from my 67 match the ones at the top and the ones from the 69 match the ones from the bottom. Is it possible that the truck I got the hood off of might have had a different hood as well. The grille was a 69 and the man at the yard said it was a 69. I'm just a little confused. :? Any clarification would help. Thanks.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
JWW
re: Hood Letters?
Post by JWW »
Or maybe the hood I have always thought to be original is not, but I'm almost positive the hood has never been replaced on my 67'.
JWW
2004 F150 Crew Cab
re: Hood Letters?
That's the first thing that gets more folks in trouble...believing that their truck's an unmolested virgin. ;)
The '67 hood has definitely been replaced with a '70-'72 hood at some point. There's no way a factory '67 hood had the top letters in that pic.
JWW
re: Hood Letters?
Post by JWW »
I spoke with my grandmother and father, and they don't recollect my grandfather switching the hood. I also can't find if any holes have been filled and new ones made to allow for the bigger letters. I'll post some pics of the hood that was on the truck. Note the square hole in the middle, this is like the 68-72 pictures. Also, there are no square holes on the outer edges, only the holes for access to the side marker nuts.
Here are the pics:
JWW
2004 F150 Crew Cab
JWW
re: Hood Letters?
Post by JWW »
More pics:
JWW
2004 F150 Crew Cab
rjewkes
Post by rjewkes »
i think they may have had the same mounting pins, or maybe somebody replaced the hood without your grandfathers knowledge. if he was the first owner he may have taken it to ford for a routine maintenance somtime after the 70-72 change in letter size occured.
and they may have had an accident with his hood and instead of saying something they just swapped on a hood from a newer truck.
theres just no way of telling. And most people would not have noticed they'd see it and swear their hood was different but tyhen shake it off.
fuelly.com
JWW
Post by JWW »
rjewkes wrote:i think they may have had the same mounting pins, or maybe somebody replaced the hood without your grandfathers knowledge. if he was the first owner he may have taken it to ford for a routine maintenance somtime after the 70-72 change in letter size occured.
If so, they found a hood with the same Rangoon red as his.
JWW
2004 F150 Crew Cab
ima71 trucks are older
Re: re: Hood Letters?
Post by ima71 trucks are older »
they may have never replaced the hood but that hood looks like its had some body/paint work long ago. thats probably when they were replaced, and they WERE replaced at some point in the last 4 decades
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
gbrett
Post by gbrett »
your letters are definatly the 70 to 72 style and they are not interchangeable the pins dont match
well that is different and i am not sure what to say. it looks as if the hood was a 67 or it was made to look like a 67 anyway. those hood letters are from a newer truck. you notice that there seems what might be a screw hole on the bottom front lip of the hood? could that be where the 70 and up chrome lip was at one time
how many rubber bumpers are on the hood are there two on each side or only one on each side?
JWW
Post by JWW »
fordman wrote:how many rubber bumpers are on the hood are there two on each side or only one on each side?
I'll have to check. I've since scrapped the hood, but I have some pics.
JWW
2004 F150 Crew Cab
