How can i keep rain out of my doors
Cowboy34
Post by Cowboy34 »
i have a 67 Ford F100 swb 2wd,,i have replaced the window felt that is on both sides of the door windows and every time it rains alot it feels my doors with water,,is there anything i can do to keep the rain out???
Banjo
re: How can i keep rain out of my doors
Post by Banjo »
I don't know where Gray TN is, but if you want to drive 10 miles south of Fayetteville, TN, I'll clean your drains for ya! I'm not intended to be a smart a$$, but it maybe you're were designed to "flow thru". I know I put new window felts on my 68, and I cleared the drains. First I do on ANY old vehicle is lay on my back and clear drains for quarters, b post, doors, inner rockers, if there is one, and fenders (again, if there is one), but I'm used to GM products with their automatic rust situations.
I do wish I had used rubber instead of the felt/rubber whiskers on my doors! banjo.
460 crew
Post by 460 crew »
If you order felts for a 70-72 they have felt on the inside and rubber on the outside to keep that rain out unlike felt on both sides in the 67-part of 70's.
Cowboy34
Post by Cowboy34 »
because of the water filled doors i am going to have to buy replacement panels for the lower part of the doors and for the lower front fender,,i will have to buy some for the 70-72 trucks,,thanks for that info just wish i had known before hand.
460 crew
Post by 460 crew »
Are the drain holes in the bottom of your doors plugged?
Cowboy34
Post by Cowboy34 »
i will check them tomorrow if i can before it rains..
