lower valance
lower valance
- kaptnkaos
re: lower valance
Hey 69 SS...
The lower valance is a single piece. There a couple of bolts on each side holding it to the fender and a couple more spaced across the valance.
There isn't enough clearance to remove it without removing the bumper first.
I just went thru that with a '69 I was trying to remove one from.
Unfortunately, I wasn't able to remove the front bumper because there was a tire carrier welded onto the cross member and was covering the bumper bolts.
I wish I could have gotten both the tire carrier and the valance off.
The tire carrier was also a hitch receiver, which is why it was welded to the cross member.
Good luck,
KaptnKAOS
Good luck,
KaptnKAOS
- Blue Cloud
re: lower valance
When I took mine off, I removed the front bumper first the the lower valance is held on by 6 or 8 body bolts.
