Removing Steering Wheel - Stripped Threads?.... Aarrg!
- hmills
Something broke inside the shift collar on my '71 F100 automatic. The shifter now moves freelly without shifting gears. I have read alot of the threads about this. I think something must have broken or come loose inside the shift collar. I am trying to remove the steering wheel with a puller but I can't seem to get puller bolts threaded into the two holes of the steering wheel. I think the threads are stripped. Anyone have any ideas?
Herb
'71 F100 Sport Custom; LWB 302/Auto
- hmills
With a little determination I was able to get the steering wheel off.
Herb
- kaptnkaos
re: Removing Steering Wheel - Stripped Threads?.... Aarrg!
Glad you got it off ok...
You really don't need a puller to get the steering wheel off one of these...
If you take the center nut off them tread it back on a few threads.. you can literally grab the wheel on each side and wiggle it lose while pulling.
You wanna make sure to put the nut back on a little so the thing don't pop off and smack ya in the face...
take care...
KaptnKAOS
take care...
KaptnKAOS
- hmills
thks k. I thought about that but after trying threading the bolts one more time i got it and it popped right off.
Herb
- Wes
A lot dirt junk and grim gets into the threads esp over @ 40 years. run a thread chaser through the hole 1st.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
