is this part of the cab corner?
to the left side of the pic, you can see that both areas at the back of the cab are rusted out. What exactly is this? Is it part of the cab corner?
- 69bumptruck
re: is this part of the cab corner?
Yep, that'd be the cab corner. LMC has replacement panels around $19.99, per side, IRCC.
That IS the front side of the cab corner...however, the aftermarket vendors only sell the back side. It'll be up to you to fabricate the front side, pictured in your attachment.
Looks to be just a flat sheet of steel.Will look at it more tomorrow.
