1967 Frame Width
ghumphre
1967 Frame Width
Post by ghumphre »
At one time I was told that the 1967 frame was narrower than other years, is this true? Additionally, is the frame width the same on 4X2 and 4X4 models?
re: 1967 Frame Width
Hey there...welcome to the forums, ghumphre!
All '67-'72 F-100 thru F-350 frames are the same width, regardless of whether it had 2WD or 4WD. The '73-'79 trucks continued with the same width on the front half of the frame but the rear half got 4 inches wider.
cancow
Post by cancow »
4 inches wider?? That sounds like a good thing! Is it?
Well, I don't know if you could call it good or bad....just different. I suppose it would help rear-end stability a bit, but it sure makes parts-swapping a PIA. The wider frame allows a rear-mount fuel tank, so if you're fixing up an old truck and have access to a '73-'79 chassis, swapping the '67-'72 body onto it is a nice upgrade, since you'll get power steering, power brakes, and the rear-mounted tank.
