Where can I get...
Where can I get...
Where can I get the little clip in square nuts that are in the rad support and inner fender/s. They are those square nuts that are push clipped into the square openings, more specificly the lower hood latch, where it bolts to the rad support. I am missing one and the others are pitiful shape.
- Thunderfoot
re: Where can I get...
You might try Ace Hardware if you have them in your area... The ones around here have lots of different automotive mounting hardware like this. I've been surprized more then once that they had a clip or fastener for my rigs...
Shayne
- Blue Cloud
Any good auto parts store should carry those. I've seen them at Napa here.
- wt4speed#2
Try some one local that carries Dorman parts and can order for you
http://www.dormanproducts.com/
You might have to dig on this site kerry but I'm pretty sure they are there someplace . Might even give you a local dist. finder
- MadMaxetc
www.mcmaster.com
McMaster-Carr. They have all sorts of crap. They are usualy cheeper that what I can get it in town.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
Ok, I have been searching high and low and cannot find these cage nuts anywhere, at least ones that will work.
I tried Fastenal, and napa, and oreillys, nada.
Anyone else found these somewhere? Last resort will be the junkyard I guess.
- rjewkes
could they be replaced with same sized u nuts?
fuelly.com
fuelly.com
