after market yoke Bolt to Bolt Length (in): 1.445 in. Bearing Cap Outside Diameter (in): 1.188 in.
seems to me that theres less material on the aftermarket one that would make it weaker. i measuse mine i the bearing cap is 1.188 and the bolt to bolt is 1.575
if you do the math stock has .5125 and aftermarket has .257 of material betwwen the bolt and the cap.
if you swicth the number around you have about .38 on both.
i think summit has it missed up but i order the wrong one once.
i called them and they have no clue. they just see what i see on there screen
i have to have an aftermarket one because the yoke is threaded and i dont want to machine one unless i have to.
i think summit screwed up myself
