Also, if I pull the ring gear housing to replace the seal should I use the actual seal or just RTV it?
Thanks for any info.
YOUR FIRED390Nut wrote:Sorry, heep, but it's not me that knows the 9" real well. However, I will say this. Having put new bearings in, your tolerances are going to be off, because you have fresh, tight bearings replacing 35+year old, worn out bearings. Even a small difference gets big in a hurry for something like a rear differential.
Setting up the rear gears is pretty critical for long life, and if you're spending the money to get bearings replaced, you might as well get it done right. If you've got the whole pumpkin at NAPA and they are doing the work for you, they should, by all rights, set it up correctly for you.
Ya cant fire me, I QUIT!heep70 wrote:
YOUR FIRED![]()
Kiddin, Sorry I bugged ya then. You have some good advice at any rate. Thanks.
