my solenoid keeps burning out what can i do?
every time i rev high or juss somethimes my solenoid burns out i dont know what to do. .
1972 ford camper special in progress
re: my solenoid keeps burning out what can i do?
then why does it burn
Disconnect the Solenoid starter wire engage wire. Measure the volts with the truck off and with the engine running the wire will read 0Vdc. It will read almost battery voltage with the switch in the start position only.
Make sure no other wires are attached to the engage wire. Make sure the ignition Hot wire is not engaged to it. The solenoid grounds it's coil through the mounting bracket make sure the bracket has a good ground.
The solenoid will burn up if the engage wire stays hot for several minutes since it is not designed for continuous use. Do not use a Solenoid for a motor later than 1980 the current requirement went down due to continuing the lowering of compression ratios.
- ICEMAN6166
a bad ignition switch can cause this by doing what kid posted about the engage wire having power when its not supposed to..
