bolts for rear leaf springs
greasemonkey1234
Post by greasemonkey1234 »
i am restoring a 67 f-100 it has 3/4 ton flex-o-matic leaf springs in the rear. I am using the polyurethane bushing set in the front and the rear. in any of the years of 67-72 pickup trucks did they use diferent size bolts in the front and rear hangers. I have a 5/8 hole and a 9/16 hole for the bushings but not on the frame. there is (2) 5/8 bushings and (6) 9/16 bushings. any information would be a help i am hoping to have a rolling chassis in a couple of weeks. i am 20 and have bulding this for a year now i don't have any idea what i am doing but i am learning as i go.
Devon
ICEMAN6166
re: bolts for rear leaf springs
Post by ICEMAN6166 »
yes there were 2 sizes, when i put the d70 on my truck i had to hunt real hard thru all my stuff to find some good 9/16 bolts from another truck i parted out before. the 5/8 bolts i bought new at the hardware but they did not have any 9/16. ford used lots of 7/16 and some 9/16 so i save those sizes whenever i can.
