1970 outer grill
LEDZEP
1970 outer grill
Post by LEDZEP »
Hey Guy's
I'm hoping someone can help me w/this? Will an outer grill from a 1972 pickup fit on a 1970?
72hiboy4x4
Post by 72hiboy4x4 »
yep, the shell will fit '67-72 trucks.
I have a shell and grille from a '71 on my 72.
LEDZEP
re: 1970 outer grill
Post by LEDZEP »
Thanks,
What about the screw tabs for the inner grill, will they all be there?
72hiboy4x4
UUMM I believe so. check the body swap info page in the tech section on this site.
Links at the top of the page.
the frame will fit on any 67-72 like mike said. but you will have a hard time swaping the inserts from year to year because the mounting tabs for the inserts are different.
LEDZEP
Post by LEDZEP »
You Guys Rock!
