Transmission will not engage.........
I hadn't started my truck in about a month. Last time it ran the tranny worked fine. I just went out to start it. The battery was dead so I had to charge it. I then attempted to put it in gear and nothing happened. I mean nothing. It felt like I had no transmission. No reverse, no forward, no nothing. The truck had not been moved since it was parked. I did tie my dog to the bumper a couple of days and he slept under the truck. Anyone got any idea what might have happened. The tranny is manual, four speed with the granny. The truck is a 76 150, 4X4. Thanks.
re: Transmission will not engage.........
Sounds like that dog was up to no good! I would give him a good
talking to. I remember when my dog hid my keys. They laugh you know.
After 2 hours of looking, he brought them back. Dirty trick!!
What ya saying, it won't move in gear or it won't go in gear? Shifter
broken? NP435?
broken? NP435?
- KevinNY
How often did you feed the dog?
Maybe he chewed thru your drive shaft? Will it go into 4 wheel drive and move via the front axle?
1969 F-250 Ranger Camper Special
"Every mile, a memory"
1976 F-250 Camper Special
Kevin O'Donnell
Carmel, NY
AKA: PiecesInPart (on Ebay)
www.VentureHosting.com
www.VentureDomains.com
Kevin O'Donnell
Carmel, NY
- lightning_msd
no gears sounds like a pressure plate to me, ive done that on chevettes and my turbo daytona but never on a bump. no gears, but you can still start it
1967 F100 "Lexxi" 352
http://www.fordification.com/galleries/ ... ?album=482
- ICEMAN6166
i think he could have put the transfer case in neutral which would cause the problem you describe.
