Has anyone used the wider rear wheels..
on their F250's. I've seen them on some F350 dentsides and I seem to remember seeing them on a bump years ago. I like the look. Do they fit on bumps without modifications? Are they 16's or 16.5's. Thanks, Chris.
- ToughOldFord
re: Has anyone used the wider rear wheels..
If you're talking about the extra wide camper-special wheels, they will fit our trucks. They're 16.5's and IIRC 12" wide.
- ratfink
Back in the '70s when I was in high school. My buddy had a '72 w/ "camper special tires and wheels. It would kick up the back of the truck, and man would those things squall when they were spinning.
Ratfink
Ratfink
Dennis
1968 F100 Ranger 390/ C6 (Mine again)
2008 Toyota FJ Cruiser Sandstorm
2007 3500 4X4 Dodge Cummins
Idleness is the mother of all vices.
- ICEMAN6166
yes i have a couple sets.
heres a pic of the early 67 inny style.later ones are outies.refers to hubcab style fit.
http://fordtruk.com/forums/album_showpa ... pic_id=562
- willowbilly3
I have had 12.00x16.5s. I haven't found any with the hubcap bumps except for the F-350 ones which take the larger studs I believe.
- ICEMAN6166
mine came off a 250, the pic shows them on a d70 rear i put on the 250 4x4.
