leaf spring bushings
When you guys repaced your rear leaf spring bushings what is the best way to get them out and if i have to cut them out do the flex-o-matic rear suspention take different bushings than the other because the parts store never asked me what suspention I have when calling for prices
- heep70
Burn them out.
Don't know if there is a difference in bushings.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
re: leaf spring bushings
Burning them out with a torch is probably the easiest way. If you don't have access to a torch, you can just drill out the rubber and then bang out the steel sleeve. That's how I did mine....I've got some pics posted of the process at the following link:
http://www.fordification.com/my67-p28.htm
- wt4speed#2
Yea they are made to be pressed in and out but if you dont have a hydralic press might as well burn em out . I had mine done all 6 bushings in and out 85.00
Tony B
Tony B
- ICEMAN6166
i use a fire-wrench.
if you dont like burning rubber (or have picky neighbors) go to a spring shop.
