question about inner fenders...
69bumptruck
Post by 69bumptruck »
Can the inner fenders from a '73-'79 be used on a bumpside? I bought a '77 with intentions of using the chasiss, but due to rust on my '69, I will use the radiator support too. Then I got to wondering if the inner fenders would work too :?
David, owner of:
1969 F100 SWB (restoration in progress)
http://www.cardomain.com/ride/2317125
390Nut
re: question about inner fenders...
Post by 390Nut »
Yep, it can be done, but read this first:
http://www.fordification.com/rad-support.htm
Paul
`69 F100 390 4spd driver
foghorn
Post by foghorn »
I was under the impresion that the frame rails on a 73-79 are 4" wider that the bump.
Foggy 8)
snake
Post by snake »
The '73-'79 frames are wider but only the back half. They get wider behind the cab......but are the same up front!
you can do it but the firewall mounts mount differently. beacuse they are wider. also you will have some trouble with the hood hinges lining up to a bump hood.
69bumptruck
Thanks for the input. I think I'll re-think it. My '69 inners maybe be salvageable.
David, owner of:
