Weird thing going on here...
blue68
Post by blue68 »
Okay...what would cause my '68 F100 2WD SWB (P/S, P/B) to start steering really tightly all of a sudden. It's been driving really nice and loose before (you could steer it with your pinky), but now you have to man handle it with two hands, especially when moving slow. It has a new P/s pump, pump cooler, P/S lines, Re-built steering column, new rag joint, etc.. and there's plenty of fluid in the tank...Does anybody have any ideas?
Thanks So Much!!! :thup:
wt4speed#2
re: Weird thing going on here...
Post by wt4speed#2 »
Lubricate the king pins . Jacup the front end get thw weigt off the pins make sure all zerks take grease. Just my :2cents:
Tony B
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
blue68
Post by blue68 »
^ Did that today and like two weekends ago. I was hoping it would help because that was the first thing that came to my mind too.. but it didn't really make much difference. Thanks anyways Tony.
If it suddenly started doing that, instead of gradually over a period of time, then I'd say your pump is probably going out. Or there's air in the system. Does it appear as if there are air bubbles in the tank when it's running? If you let the fluid level get too low and start sucking air before you topped it back off, you might need to bleed the system to purge the air.
bluef250
Post by bluef250 »
You might check to make sure the belt is tight and not slipping.
mcarlson11
Post by mcarlson11 »
most likely you have air in the system. Make sure you dont have the hoses crossed up either.
When the going gets tough, your doing something right.
Big D's 69
Post by Big D's 69 »
I know when I changed my rag joint my steering got a lot tighter. Don't know why, but it did. I loosened the bolts just a little and it loosened back up a little. Not as much as before, but it was better.
ExplorerNC
Post by ExplorerNC »
I would say if you just replaced the pump and all, it probably has air in the system and needs bled. Cost free starting point at least.
1972 F-100 "Explorer"
1971 F-250 "Custom" (SOLD)
1965 F-100
1966 F-100 4X4
ICEMAN6166
Post by ICEMAN6166 »
i also think its an air issue.otherwise the pump is suspect or could be a bent/ kinked hose.
excellent avatar btw.
blue68
Post by blue68 »
Soo.. I drove the truck 15 miles today and it got quite a bit better. Its almost like something is fixing itself. So, I'm guessing it's air. So how Can I get the rest of the air out of the system, 'cause I can feel some more in there. Just keep on driving it?
i think if you jack the truck up and turn the wheel all the way each way two or three times that might do it.
