wheel studs
customcrewcab
wheel studs
Post by customcrewcab »
does anyone know of any other companies that makes studs besides the one's summit and jegs sells like arp. i need some with about 2.5 inches of thread. hub is about .70 deep. i have to run about a one inch spacer for my brakes and my wheel is about a half inch thick. i would like to have 3/4 to inch on the nut threaded. need to be 1/2 20 and not have a huge knurl. :?
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
ICEMAN6166
re: wheel studs
Post by ICEMAN6166 »
later model ford trucks and vans from the 80s have longer studs.i have several different lengths in my shop. they are all from dorman products and came from the auto parts store.
