Kick out of Reverse?
cghstrojan08
Post by cghstrojan08 »
I have a 3 on the tree. When you put it in reverse, it will kick out as you go backwards. You have to kinda hold it up to make sure it doesn't go into neutral.
ROBERT
Member #1076
1968 F100 SWB 360
ToughOldFord
re: Kick out of Reverse?
Post by ToughOldFord »
FWIW, I don't know about Ford's, but I've had Mopars with 3 on the tree and the fork travel and "slop" was adjustable under the hood.
Of course a wore out gear box will do that too, only I've never heard of wearing out reverse since it isn't used that often.
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
Heavenlyfire
Post by Heavenlyfire »
Should be adjustable, but I don't remember which way.
ICEMAN6166
Post by ICEMAN6166 »
adjustment is possible but if it has been doing it for too long, the gear teeth will be worn on the edge and it may not help.
cghstrojan08
So, where do I adjust it at? And what way do I turn it?
ROBERT
Member #1076
1968 F100 SWB 360
