anyone know if front stabilizer bar from 73 to 75 will bolt to a 66
f250 camper special. probably have to drill holes for stabilizer mtg on frame. is frame same width?
stabilizer bar
re: stabilizer bar
A factory swaybar from a dentside truck ('73-'79) is a direct bolt-on for all earlier Twin I-beam trucks. The end links attach to a bracket mounted under the coil spring. The only holes you'd need to drill are the for the frame support brackets.
re: stabilizer bar
speaking of sway bars, do any aftermarket ones work with our suspension?
When the going gets tough, your doing something right.
re: stabilizer bar
Sure, Addco sells complete kits. Here's a pic of one installation...this is an Addco ACO-113G:
If you're good with mild fabricating, you can easily adapt just about any swaybar. Here's one from a Ch*bby that someone installed with homemade brackets:
- MadMaxetc
re: stabilizer bar
I orderd both the front and rear sway bars from Summit
ACO-113 & ACO-209G
I will let you guys know how they go on my 67.
ACO-113 & ACO-209G
Dan
FORD Girl
Photobucket Pictures
FORD Girl
re: stabilizer bar
Cool, I would appreciate that.
- zakt
re: stabilizer bar
I will be using a 95 front D60 and D70 rear so I have the swaybars from a 95' F350 and a 85' F350 so hopefully one of those can be made to work. I thinking though that those are for the wider frames so if I used them the mounts wont be on the ends of the bar before it goes down to the axle so that may be a problem might have to get the 73-79 for the frame width??
1972 Ford F350 crewcab
re: stabilizer bar
I installed the front and rear that LMC sells which from the above pictures is indeed Addco.They do help the sway but makes for a stiffer ride.Not too bad to install.I was a little scared to drill through the i beams but they are not as tuff to drill through as I thought.I do recommend them,and they are not too pricey either.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
