Master Cylinder Reservoirs-front and back
- mytmatt
I had the impression that the rear reservoir was for the rear brakes, front was for the front brakes. I just bled my front brakes only, and the rear reservoir needed fluid (drained as I bled the brakes), not the front. Can someone educate me as to what is going on here, please?
Matt
Matt
re: Master Cylinder Reservoirs-front and back
As you've found out, it's the opposite of what you'd think. The front reservoir is for the rear brakes, the rear resevoir is for the front brakes. Most replacements now have a large rear reservoir and a small front. The large is always for the front brakes.
- mytmatt
Thanks Keith! I am always looking to expand my knowledge of how my trucks works, and this is an interesting subject to learn about.
Matt
Matt
- FLATBEDFORD
On my '70, the rear chamber is plumbed to the rear brakes. That's the way it was when I got it.
Steve
My Photo Gallery
My Photo Gallery
Sounds like you need to do some re-plumbing.
- FLATBEDFORD
As I recall, both chambers arethe same size. Drum brakes.
Steve
My Photo Gallery
My Photo Gallery
- ICEMAN6166
it still makes a difference.
<bump>
'92 Mercury Cougar
did you need a measurment off a bracket?
'92 Mercury Cougar
