Concerning por15
$500F100
Concerning por15
Post by $500F100 »
Is it necessary to use the metal ready product that por15.com recommends before applying por15 to a rusted surface?
1970 F100 Sport Custom 360ci LWB
My Truck
thats what they say. otherwise it won't work properly.
lightning_msd
re: Concerning por15
Post by lightning_msd »
thats some expensive sh*t :eek:
averagef250
Post by averagef250 »
No kidding. Top quality epoxy urathane equipment enamel is $80 a gallon and lasts decades under marine salt spray conditions, that's 3 lifetimes on a daily driven pickup.
But you have a have a spray gun, large air compressor and all the equipment (and in a clean environment) to use that. Plus you have to clean all the rust off first, usually by sanding or sandblasting. That's the beauty of POR-15...the only prep equipment required is a wire-brush (to clean off flaky rust and paint) and some MetalReady, to give the surface an etch, which allows the POR-15 to stick. The only application equipment needed is a brush or roller, ...and finally, there's virtually no clean-up. You simply toss the brush/roller in the trash when you're done.
For someone working at home, in a driveway or small garage with limited tools and equipment, this is the best route IMO. You can get a 6-pack of quart cans of POR-15 for less than $50...and you can do an entire frame of a truck using maybe a quart, if even that.
ICEMAN6166
Post by ICEMAN6166 »
POR 15 is well worth the money.do it by the directions and it turns out great.not only have i used the black for the frame but the thick grey stuff on the floors of the cab with some fiberglass mat makes strong patches.
also used the hardnose paint on the firewall, kickpanels and stepwells of my 66 4x4.
all done with a brush, its free flowing so you get no brush marks.
save your brush, after the por hardens it turns into a chisel.
lightning_msd
ive used it before and i know its some tough stuff, i just didnt realize how expensive it was, i always used left over cans at work :lol:
jbrown414
Post by jbrown414 »
Would anyone recommend against using por15 on the whole body of a truck?
flyboy2610
Post by flyboy2610 »
You could do it, but you would have to top coat the POR-15 while it was still tacky, or use POR-15's tie coat primer. POR-15 is sensitive to UV rays, so if left untopcoated it will turn chalky.
The silver POR-15 will not prodiuce a perfectly smooth surface.
You could use POR-15 to paint a truck, but it would be a lot of work.
That's what I'm going to be doing with my chop-top! :D
ICEMAN6166
if you use their hardnose paint you can paint the whole truck.its 2 parts , color and hardener.i have been stepping on it with dirty feet for a couple years and it has not changed, but its very slippery so i have to be careful if my feet or the stepwells are wet.
i really did not think the expense was that bad and i had to pay the shipping up here.i know for all i bought it was less than $200, and that was 2 separate orders.
i know a guy from Kodiak, way down where the salt water spray from the wind rusts things pdq, he told me they love the POR15 there.they use it on anything metal they want to keep outdoors.
OldBlue67
Post by OldBlue67 »
They mean it when they say dont get it on you!! Nothing will take it off. I think the only reason it comes off is you shed the skin cells its attatched to.....ask me how I know ;)
~Liz
Old Blue Truck is Old and Blue
Ugly as sin but dont get in my way VA-ROOOOOOMMMMM!! :evil: :evil:
jbrown414
Post by jbrown414 »
flyboy2610 wrote:You could do it, but you would have to top coat the POR-15 while it was still tacky, or use POR-15's tie coat primer. POR-15 is sensitive to UV rays, so if left untopcoated it will turn chalky.
If I were to do it, it would be a sectional process and I would put a primer over it.
$500F100
Post by $500F100 »
I read up on rust bullet. Based on their claims and my budget, I am going to give them a try. I will keep my results (before and after) posted. Thanks for all the input.
My Truck
theskytoucher
Post by theskytoucher »
I'm thinking about using the por 15 on my engine the next time i rebuild it and i was wondering if anybody had used there engine enamal? And has anybody used por15 on headers? Im wondering if it will hold up to heat?
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
