weight of a disc brake supension
Anybody know the weight of a Front disc supension F-150 78???
- theskytoucher
re: weight of a disc brake supension
Probably about the same as a F-250 250lbs
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
I would think its less afterall its a half ton setup you cant use it on a 3/4 ton so it lighter imo
- theskytoucher
In looking at both setups there might only be 10-15lbs difference. My
-Troy-
1976 Ford F-150 4x4
1976 Ford F-150 4x4
i think that the disc front end with everything hoooked to it including the calipers would be about if not a few pounds heavier than a drum front setup.
i know once you get the front end out from under the frame it is basically two big pieces. the tie rods split from the drag link and goes with the drivers side and the drag link goes with the passenger side.with the springs and all of that attached i can pick up one half of the front end and load it into a bed of a truck. so i would have to say it got to be near 200-225 pounds for the whole setup.
thats what my thoughts were around 200 the f250 is a much stoutter setup beams and radius and spindles hubs are heavier.
