I'm going to switch my 67's T-18 for a C-6 automatic. Instead of replacing my steering column, I think I'll go with a floor shift. Recommendations? Thanks.
jor
Floor Shift
- jor
- Galaxie64
I have a C6 in mine and the floor shifter crowds my right leg pretty hard. If I ever get around to it I'd put an L in it to center it a bit. Not a huge deal but I don't have the kickdown rod installed yet so i manually shift 1-3-1 to be safe.
To get a better idea the shifter comes almost through the floor pan on the drivers side rather than the tranny hump. I think the PO just found what ever shifter he could and slapped it on, its only about 16" long. I think it could easily be centered and have a console built around it. Might have to make the linkage to center it though, I am not sure what is out there for such a project.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
- GT-Racer
re: Floor Shift
Check these out for starters from summit. I ran the car version of the mega shifter for years with no problems. I loved it. Installation is a breeze.
http://store.summitracing.com/partdetai ... toview=sku
And for more of a 4 speed look try this one...
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
re: Floor Shift
just switched mine from colum to floor i love it
- jor
re: Floor Shift
Tynall,
Did you get one of the Summit models that GT is suggesting?
jor
jor
