Headlight Bucket
ToughOldFord
Headlight Bucket
Post by ToughOldFord »
Anyone know if the same ones used in the bumpsides was also used in the dentsides? :?
TIA
i'm pretty sure they are different
390Nut
re: Headlight Bucket
Post by 390Nut »
I think they are too. I'll find out tomorrow afternoon, got a dentside out there minus the headlights, and have to dink around with the final fitting of the harness tomorrow on the `69.
Paul
`69 F100 390 4spd driver
rjewkes
Post by rjewkes »
On the 77 f150 Core support the buckets are built into it at factory. Then the Inserts go around it. Even without a grill on a dentside you still have headlight buckets. or atleast the thiung the buckets sits in is done that way.
fuelly.com
390Nut
Post by 390Nut »
Same on the `73 outside, the bucket is seperate from the grill, and you can pull the grill of with the buckets in place.
Paul
rjewkes wrote:On the 77 f150 Core support the buckets are built into it at factory. Then the Inserts go around it. Even without a grill on a dentside you still have headlight buckets. or atleast the thiung the buckets sits in is done that way.
The dentside and bumpside radiator supports are basically the same there. There's an indention in the support to clear the headlight bucket. However, I'm not sure if the '78s and '79s with the square headlights continued to use the same core suport or not. I'll have to check that.
Anyway, to answer the original question, the headlight buckets themselves should be the same between the two eras...I don't know why they'd be different, since they have basically the same core support and use the same headlights.
oh yea the buckets should be. i was thinking of the outer headlight doors.
rjewkes
Post by rjewkes »
yeah i double checke mine and they do look very similar infact i think i replaced one on the red and black truck in my sig with the one off the 77.
Does the newer supports built inbucket holder work with the older grill? Or do they have to be removed?
fuelly.com
i don't think the core support is any differnent even with the square headlights. its just a bucket change is all thats need on 78 79 to go from round to square.
two-bit
Post by two-bit »
My 72' has a core support and inner fenders from a 78'/79' square headlamp truck. Core support fits just fine. Had no problems with my 72' grille and headlamp buckets.
Two-bit
ToughOldFord
Alright then, thanks guys, I'll give it a try and let you know. The '67 had a light bucket that's garbage and I have a '76 that I'll more than likely end up parting out so I'll grab the bucket out of it.
Randle
Post by Randle »
I have another question, Dennis Carpenter & LMC shows headlight buckets for 67-69 but not for 71 & 72, are these the same.
Big D's 69
Post by Big D's 69 »
two-bit wrote:My 72' has a core support and inner fenders from a 78'/79' square headlamp truck. Core support fits just fine. Had no problems with my 72' grille and headlamp buckets.
Two-bit
Hey post some pics of that setup. I'm curious to see how it all bolts up and looks. :D
i'm pretty sure they are the same.
ToughOldFord
I haven't tried the 76 bucket on the '67 yet, but to add to the conversation; FWIW I put the headlights and grill assembly from a '79 on my '77 without any alterations. Core support was the same, at least in that area.
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
