So close, can only be 1 wire off from running!
I'm getting excited, after putting a roller cam motor in 68 SWB, I have it close to running, but need your suggestion. It'll crank and run with the ignition switch held in the start position. When I release it and the switch returns to "run" position, the truck dies. So, I'm losing voltage somewhere. When converting from points distributor to factory duraspark stuff, I must have missing hooking up 1 wire somehow. I ran the red wire off the duraspark to the red/green off the coil and also wired in another thick brown wire that runs into the firewall and to the ignition switch. I ran the white wire off the duraspark to the "s" terminal on the starter solinoid. I'm just not real good at wiring, but I feel I'm only 1 wire off from running and solicit your help. Is there a ballast resistor I was supposed to have removed (I don't even know what it looks like or where it is) or what am I doing wrong? I really thank you guys for your advice and help (in advance)....I appreciate you. The old banjo.
re: So close, can only be 1 wire off from running!
If you don't already have the wiring diagram this may help....http://users3.ev1.net/~bmarr/57bcfe50.png
Jim
'75 Ford Highboy 390 4spd
Montana, I had that picture, but due to limited space under the dash and herniated disc, I wasn't able to stay under there long to try to figure out hooking the wires in that way, so I hooked the red wire to the red/green on the + side of coil and the white wire (these are the wires on the duraspark ignition control box) to the "s" terminal of starter solenoid. I was able to do that without enduring back pain.
I have been searching and reading, and someone has messed with this truck in the past, there is no thick pink wire I keep reading about. And, now, I'm reading about some kinda "resistance" coil, which I didn't know existed. I know the prior motor, that was running, but tore up, was an '83 Mustang GT 302, and someone had wired it for a points style distributor.
I have inserted a 90 Lincoln 5.0 (rollercam) and using a '85 Mustang GT distributor with steel distibutor gear and plugging that into the factory duraspark connector. I can only be one wire off, because as I mentioned, if I hold the key in "start" position, it'll run until I turn loose and the key falls back to "run" position and obviously voltage is gone (or drops) and truck dies. ??? the old banjo.
sorry, my train of thought got derailed on typing that last one (happens often)....where I was going with the "resistance" coil...is, how would I know if I have one, and maybe that is my problem, maybe I'm trying to use the wrong coil? I have 2 normal looking coils laying around, one that was on the truck when it was running points, one that's off a stock 78 or 79 truck with a 302....and one that is off the 90 Lincoln towncar I took the motor out of, but it's not a "normal" looking coil, it's a little small squareish looking deal that I figured isn't compatible with older system.
I can't be but one wire off (somehow), but from looking, someone has monkeyed with the wiring some in the past to insert the prior motor. so I'm just lost, but I admit, I'm not smart about wiring and do admit a problem even with reading wiring schematics. I truly appreciate everyone reading and helping with my foolishness, I need to get this 68 F-100 running so I can figure out how to fix the heat in my newer F150. I figure when I start in on it, I'll break something, so I need a running backup. Banjo.
the only pink wire i have ever seen on these trucks comes from the cab in a group of three wires from the center of the firewall. i think it goes to the dist. but i can't remember for sure on that. it also wasnt a large wire that i remember seeing either. it is a small wire. maybe a 16 or 18 gauge wire.
- rjewkes
wondering if the control bax has 12v + at all times or atleast during run.
fuelly.com
fuelly.com
- Wolf0r
Yes what Ladz said. You have to run a wire from the R to your box. The other to 12v ign. This is assuming you are using the "blue" box. If it starts and then dies swap those two wires.
Also those who run a holley with the electric choke, you can run your B+ wire to the choke from the "sta" on the alternator the one with the black insulator. It's about 8volts. I am using a factory 85 5.8 HO holley and it purrs like a kitten.
