Click, click, click...?
- nikon4u
I am trying to go back to work and I can't get my truck started! I turn the key and hear a click and that's it. Battery is good to fair. I replaced the starter sillinoid this morning. The starter works. What else could it be?
HELP!
HELP!
I just got my web site up! Check it out!
http://www.Handyman-for-rent.com
"If it ain't broke, don't lend it"
--Red Green
http://www.fordification.com/galleries/ ... ?cat=10491
--Red Green
re: Click, click, click...?
Loose and/or corroded battery terminals. Even if they look good, clean 'em up and make sure they're tight. Also make sure the battery ground cable is tight where it attaches to the block.
It sounds like it's not making a good contact somewhere does the motor turn at all??
- nikon4u
No the motor doesn't turn at all. All connections have been sanded to bare metal.
--Red Green
--Red Green
- rjewkes
try turning your key on to start make sure your in park and take a screw driver and jump the selinoid right where the battery and S terminal is if it starts it'll get you to work.
Then when you get out of work later you can double check everything.
fuelly.com
fuelly.com
- nikon4u
And what is this?
--Red Green
--Red Green
- bluef250
The metal box looks like the horn relay. Was it right beside the starter solenoid?
Sounds like you have a bad battery (first guess) or badly corroded cables. I would have the battery load tested.
- nikon4u
Well my new starter just came in. I'm going to put it in and wait for my wife to get home so that I can jump start and pray that that fixes it
--Red Green
--Red Green
- nikon4u
At 4:14 PM she started to take her first breath and then a loud growl!
--Red Green
--Red Green
- nikon4u
Make that 5:14. It's Central time here, I forgot where the site is located.
--Red Green
--Red Green
- jor
So what was he problem, nikon? I would be very surprised if it were the starter.
jor
jor
- nikon4u
I am almost thinking that the starter gear was starting to burn up and was causing it to lock-up. Or at least get stiff enough to need a ton of power to turn it. My alternator belt was also pretty loose and maybe keeping the battery from getting a full charge. I did see that the starter gear teeth were all chewed up and parts of the flywheel have seen better days...a lot better days! I think that maybe it was a combination of a couple of things that caused it.
Whatever...it runs now!
--Red Green
--Red Green
