My father was driving the truck
(69 with a 3 speed collumn shift and 360 c.i.) and told me he had to come home in 1st gear. I give it a shot and the danr thing wont start cuz it wants to take off.
And yes i am holding the clutch in when starting it haha
clutch wont hold truck back
- heep70
re: clutch wont hold truck back
Check the linkage to make sure it is all good. Then try adjusting it.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 72hiboy4x4
start it in gear, then float the gears all the way home. not too difficult to do with a little practice.
or the little plastic thingy in the column is worn out and needs replaced.
- kknip
Sounds like the clutch arm pivot point might have broke or something in the linkage as heep said.
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
- mrung0wa
Re: re: clutch wont hold truck back
heep70 wrote:Check the linkage to make sure it is all good. Then try adjusting it.
Yup, that's what I would do 1st!
Good Luck!
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
- theskytoucher
And make sure to check every component of the linkage. I ended up replaceing a clutch because of a similiar prolem when the only problem was the piviot on the frame was loose and giving to much slack.
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
