Decided to remove all the body mounts before I either powder coat or POR 15 the frame and mounts. Notice some had where the powder coat was missing around the brackets... also had to drill the holes bigger to 7/16 since the solid rivets are smaller. Now wondering about coating both the bracket and the frame on how far the mount will be then from the frame with the thickness of both...thought maybe just paint the bracket side that attaches to the frame to get away from being to thick on that side? Any thoughts?
Todd
removing body mounts
- zakt
1972 Ford F350 crewcab
![Image](http://www.fordification.com/galleries/albums/userpics/10045/350emblem~1.jpg)
- 72hiboy4x4
I wouldn't think the power coat would be that thick too worry about it. a few thousandths of an inch, maybe?
