'99 8 lug F350 rims fit '72 8 lug?
Galaxie64
Post by Galaxie64 »
I am looking at some rims that fit a '99 F350, will they fit on my '72s hubs and studs?
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
72hiboy4x4
Post by 72hiboy4x4 »
nope wont fit. they changed (in '97 or so) to a flat lug nut and a metric (115mm, i think) lug pattern.
Galaxie64
Post by Galaxie64 »
Its 170mm on the 8 lugs and they are hubcentric rims but I thought I may be able to get away with either using lugcentric lugs backwards or find hubcentric lugs that fit my studs. Guess I'll have to save up for some of the ones out of LMC.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
