Questions about drop coil and leaf springs?
- Big D's 69
So I see that LMC trucks offers 2 inch drop coil springs. Will thes affect teh camber of our trucks? I was planning on using the two inch drop coils and having a set of 3 inch drop leaf springs. We have a company here at work that builds modified springs so I'm hoping that I can get these and go that route. Does anyone see any problems going this route?
- SmokeyBear
It will affect the camber but it shouldn't be enough to worry about. remember your axle swings in a long radius from the pivot point on the other side so anything shorter than stock will put the camber out of original spec BUT with that long arc, I beam trucks can handle more travel before being severely effected.
70 F-100 XLT
72 F-100 Ranger XLT
72 F-100 Ranger XLT
- Big D's 69
I knew I could count on you Smoke. That is what I was thinking but just wanted to check. WOuld save a ton of money for another inch in the front. But a good front end guy that knows I beam trucks could realign it to get it back in specs.SmokeyBear wrote:It will affect the camber but it shouldn't be enough to worry about. remember your axle swings in a long radius from the pivot point on the other side so anything shorter than stock will put the camber out of original spec BUT with that long arc, I beam trucks can handle more travel before being severely effected.
