Cab Mount Help
cghstrojan08
Cab Mount Help
Post by cghstrojan08 »
Do you think I should try to replace the cab mounts or should I have it done? I have a guy that will do it for $300. They are rusted out in the front and affecting my steering column. It has pushed it up. I am getting ready to install PS and I don't know if I should have the cab fixed first or it doesn't make a difference. Thanks!
ROBERT
Member #1076
1968 F100 SWB 360
Tim P.
re: Cab Mount Help
Post by Tim P. »
Fix the cab first as this will hinder the new install when you pull the colume the cab will drop most likely making it hard the realign the new setup.
foghorn
re: Cab Mount Help
Post by foghorn »
:yt: :stupid:
Tim P.
re: Cab Mount Help
Post by Tim P. »
HEY I resembled that remark :lol:
re: Cab Mount Help
once the cab mounts are fixed look at your column and make sure it didn't put a groove all the way around the shaft. if it did i think you can safely fill the groove with a weld.
