Brake Light
- cghstrojan08
Brake Light
There is a little circle light in the bottom left hand corner of the dash. Is that the e-brake light? Mine isn't coming on. I tested the outlet where you put the bulb and there is nothing. Where does the light connect to the e-brake? Thanks!
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- flyboy2610
That light is connected to your distribution block. There is a valve in there that is normally centered. When one side of you brakes system devolps a pressure loss, that vale goes off center and turns on the warning light.
- HugYourPlumber
- cghstrojan08
Distribution block? So how do I test it?
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
In my opinion the Stickied "FAQ" Threads are hidden down in the Registered Users Only forum.cghstrojan08 wrote:Distribution block? So how do I test it?
Here is a good thread on fixing your problem:
http://fordification.com/forum/viewtopic.php?t=2214
Information pertinent to you starts a few posts down in the thread.
- flyboy2610
You don't want it to come on. If it does you have an unbalanced brake system. To find the distribution block, trace your brake lines from the MC to where they enter a metal block. That's it. There is an electrical connector on it. That is the wiring for the indicator light. I'm not sure how to test it, though.
I think it's supposed to come on briefly when the engine is started.
- cghstrojan08
I tested it and it is always on. I read the thing you posted. So, I can't buy a new one? I really hate bleeding brakes. I had to replace the mc twice. I got a rebuild one and it was bad.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- flyboy2610
There is a way to recenter the valve, but I'm not sure how it's done. Somebody can probably tell you how to do it.cghstrojan08 wrote:I tested it and it is always on. I read the thing you posted. So, I can't buy a new one? I really hate bleeding brakes. I had to replace the mc twice. I got a rebuild one and it was bad.
- cghstrojan08
The bulb was burned out but I put a light tester in the socket and it is always on.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
That means the brake system is not centered, once you bleed the brake system you can centered the system which turns off the light by turning on the key (key on engine not running) and push the brake pedal hard severel times as far as it will allow sometimes this can take a lot of pedal effort this should center the system and turn off the light if not rebleed the brakes and do the above all over again this can take some time as the dis block can be stubborn at times, once the system is centered the light goes out and you have equal pressure in the system as it should be. After that the light only comes on for a moment while the key is turned on in the start position durning cranking then goes out ,this is a test thing so you know its working proper, so replace the bulb and do as suggested above. BTY the switches almost never go bad in fact I've never seen one go bad.
