automatic overdrive
rsjohnsn
automatic overdrive
Post by rsjohnsn »
I would like to have an auto for my 390 engine but I would like it to be an overdrive version. Is there such a beast or something that I could make work? I have a 4 speed overdrive unit but I am tired of changing gears. I know I could install a C6 and then an aftermarket O/D unit after that but that is getting pretty long and I'm not sure how that would do on the pinion angle. What are you guys doing that have O/D's?
Scott
'67 F100 4x2 SWB Custom Cab
'68 F100 4x2 SWB Ranger - 360FE
'84 F150 4x4 SWB XL - 300 Inline 6
'04 F350 4x4 CC DRW - 6.0 Powerstroke
'06 Expedition SVT - Blown 5.4 V8
splavin90
Post by splavin90 »
aod
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
Clarko
Post by Clarko »
Ok, you will need to buy an adaptor: http://www.transmissionadaptors.com/ford_fe.htm
And then use a BUILT UP AOD or an E4OD with an electronic trans controller
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
tynall44
aod
Post by tynall44 »
alot of the aod"s work on a detent cable just like a chevy check it out
Clarko
Post by Clarko »
All AODs work with a throttle valve cable.
Brian
ToughOldFord
Post by ToughOldFord »
The E4OD is garbage stay away from it.
I don't have any experience with the AOD, from what I've read it's rather light duty, but it seems to be the preferred choice of the OD trannies.
If it was me and I had the coinage I'd stick with the C-6 and put a Gear Venders or a similar overdrive unit behind it.
Galaxie64
Post by Galaxie64 »
lol most people who use the newer 4R70 and E4OD/4R100 think the AOD and AODE's are garbage. I've put an E4OD through a lot of crap and never had a problem in 200K miles. For ease though I'd stay away from the elctronic trannies and go with an AOD.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
ToughOldFord
My '92 F-350 has the E4OD behind the 7.3 diesel. That tranny is a turd and from all the research I've done on them since I bought the truck I found that they pretty much all are. 120K seems to be the average life of them, some even died @ 15K. A few people reported 200K+ but they weren't the norm. When mine dies I will upgrade to a c-6 or a manual if I decide to keep the truck. I never would have bought the rig had I known about the E4OD.
MLPS, TPS, VSS, solenoid packs, etc... yick....
Clarko
Post by Clarko »
That's before the updates, the stock E4OD sucks @$$
Build it up and you have one hell of a transmission
Brian
Tim P.
Post by Tim P. »
I have a e40d in my 96 got 130k still shifts great but will rebuild it when its time and do the up grades did change the fluid this spring was very impressed only a pencil eraser amount of stuff in the pan.
Clarko
Post by Clarko »
Well 95 was a BIG upgrade year but the final version came out in 1999
Brian
Tim P.
Post by Tim P. »
As in ?? is this up grade possible with the 96 models yrs?
Clarko
Post by Clarko »
As in 94-earlier were the worst
95-98 were ok
99-up are the best
When you get it rebuilt and updated, they build it as if it were a 99-up.
Brian
Tim P.
Post by Tim P. »
You lost me
Tim P.
Post by Tim P. »
you lost me
