shifter removal
fourtss
shifter removal
Post by fourtss »
anyone know how to remove the shifter on a 4 speed granny trans? :hmm:
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
ToughOldFord
re: shifter removal
Post by ToughOldFord »
If I'm thinking of the correct tranny, that cone at the top of the transmission cover unscrews, use channel locks or a pipe wrench.
fourtss
re: shifter removal
Post by fourtss »
thanx, I was wonderin if that was possible, my tranny is the one were reverse is away and down.
tom
2003 ford escape
460 crew
re: shifter removal
Post by 460 crew »
Don't you push down and turn the cap just with a firm grip? I has 2 keeper pins that it is held in by spring pressure or something It's been a while.
ToughOldFord
re: shifter removal
Yep, that looks correct. I might be thinking about a different tranny. What I'm thinking about is where the tope cone is a thin steel cover that has four straight edges to grip, but it's not really square.
ToughOldFord
re: shifter removal
Okay, I think this clears it up, it looks like the T-18 used two kinds, I found this site that shows both:
The early type that 460Crew posted:
And the later one that I was talking about:
http://partsmikeparts.com/t18%20ford%20and%20jeep.htm
I'm probably remembering the later one as my '79 was the last T-18 I've worked with.
fourtss
re: shifter removal
Post by fourtss »
mine is the newer one, w/the cap on the inside, is that the one u push in causechannel locks don't grip it and it cannot b pried up :hmm:
tom
2003 ford escape
67highboy
re: shifter removal
Post by 67highboy »
If your reverse is away and down I think you have a NP435 wich will have a stamped steel ring with a cam lock just as you said push down and turn
But all the T18's I have seen reverse is over and up so I think you have a 435
John
Ben Franklin 1775
fourtss
re: shifter removal
Post by fourtss »
Think ur right again highboy' however I have a 65 f250 w/the granny low over and down and it has the pry off cap around the shifter, what tranny might that b :hmm: :hmm:
tom
2003 ford escape
spartman
Post by spartman »
I got a shifter from a 75 that had the T-19 with reverse to the passenger side and down and it had the screw on type retainer.
Fit just like a glove on my 67 T-18 box.
The other style I believe was only used for NP 435's
