Lowering flexomatic
Lowering flexomatic
I completly sanded and treated my flexomatic spring set up with por 15. Now someone said I cant use the lowering shackles to drop my back end 2 inches. Somone please tell me he's lieing
I even bought new prothane bushings.
re: Lowering flexomatic
They're correct, lowering shackles won't work with the Flex-o-matic setup. In addition to needing straight shackles, you'll also need the matching springs, since Flex-o-matic springs are a different length than standard springs.
- green70
told ya!
whats the difference between flexomatic and regular springs?
To my understanding there just a haevy duty type for carring heavy loads. This really sucks big time, should have researched before I jumped into the hard work. I guess I'll have to find another type of spring. How about the axle flipp kit with some blocks to reduce the lowering an inch. I am only looking for 2-3 drop someone help.
- DuckRyder
They are supposed to improve the ride with light loads.
Flipping the axel should work fine.
- green70
with an axle flip,adding blocks will just make it even lower,and i think if you move the front hanger it will throw the pinion to far off,i think your only solution would be to change the springs or just slam it!
- binder56jd
It would entail some fab, but why not move the rear shackle mount forward to match the spring length and then use the lowering shackle?
now serving #235
now serving #235
- DuckRyder
Re: re: Lowering flexomatic
Ah yes, it was early and I didn't catch the part about the blocks.green70 wrote:with an axle flip,adding blocks will just make it even lower,
If you flip the axel, what you end up with will be as high as it can get, blocks will only lower it more.
You could try contacting a spring shop to see if they can de arch your springs a bit, but I would be surprised if it cost much less than new springs.
- theskytoucher
Is it possible to change the flex-o-matic springs tio the non flex-o-matic style with just changing the shackles and the springs?
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- green70
yes but i think you also need to change the rear mount
No, the mounts are the same...if we're talking about the ones riveted to the frame on each end. It's the springs and shackles that must be a matched set. You can't intermix Flex-o-matic parts with a standard shackle setup, and vice versa. My '67 originally had the straight shackles, but I installed the Flex-o-matic setup and springs from a '68, and they bolted right up.
- green70
cool,that would make changing it over that much easier...
- 67effie
If you spent all that time and money I would just spend a little extra and flip the rear axle, notch the frame and call it good. This is what I did to mine. If you go this route though make sure you relocate the shock mounts other wise they will hit the axle housing.
Good luck.
Good luck.
If at first you don't succeed. Get another beer.
Jeremy
1972 F-100 - currently under going complete frame off restoration
1997 Mustang GT Convertible- (gone but not forgotten, damn unemployment)
1996 Saleen S281 #247
1988 - Coupe, OSP car sold to public NEW, under construction, 1 of 3 that was supposed to go to Saleen in 1988.
http://www.fordification.com/galleries/ ... ?album=270
Jeremy
- green70
really,thats odd,my shocks mounted up just fine,problem with the flip is that he only wants a 2-3"drop.....
