truck electricals wimping out
Can any one help?
My 85' F-350 headlights are on the dim side as are the dash lights. Come to think of it the horn sounds but you can put your head next to it and the sound wouldn't hurt you.
Any ideas out there??
67 Austin Healey 3000- resto - subframe rebuilt so far
68 F-100 LB w FE410-in progress frame-off resto
02 Sebring Convertible- for top-down relaxation
re: truck electricals wimping out
Come to think of it the fuel gage is real slow moving. I have dual tanks and when I switch it takes the guage a couple of minutes to move if at all.
Could this be tied into my other problems????
- flyboy2610
Clean your negative battery terminal.
My dim switch also is a 3-way switch. It give me either high, low or no lights. Could that be the problem?????
- adrianspeeder
The gauge is naturally slow on switching. Turn the key off then on for an instant reading.
Check your grounds, but in the 80s ford really skimped on the wiring sizes. I rewired my 84s headlights straight to the battery with relay controls. SUPER bright with normal bulbs.
I'll post a writeup on how to soon.
Adrianspeeder
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
I'm looking forward to your diagram
Clean and or upgrade the wire size on all your ground leads. I had dim headlights on my old 68 F100 SWB and just cleaning the ground lead behind the left headlight made them go (both) real bright. My halogens were real dim and the same thing was happening on this truck
- Clarko
If you're not up to making a relay harness, here's one for sale:
http://fordfuelinjection.com/?p=66
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
- binder56jd
good stuff clarko- thanks
now serving #235
now serving #235
Re: re: truck electricals wimping out
Not natural Shoot the Demon Dimmer Switch and get another one.F-100Ranger wrote:My dim switch also is a 3-way switch. It give me either high, low or no lights. Could that be the problem?????
