more gremlins
- 19674x4
more gremlins
some times when i go to start ol blue up it barely cranks over. so i let it sit for a few seconds and each time i crank it over, it gets faster until it finally gets enough rpms to fire over. then some times i crank it over and it cranks fast and fires after one or 2 cranks. then sometimes it will barelly crank so i let go of the key then immediatley try again and i turns over real fast and fires up.
i cleaned the posts and connections and it still does it. could it be my relay?
My Photo Album
- Mohillbilly
It's possible. Have you tried "jumping" the solenoid (shorting the Battery side to the first small connector)? If that makes it start ok, the solenoid is good. Could also be a loose/ dirty connection at the starter, or the starter solenoid/ gear assembly dragging. Hope this helps.
70 Custom LWB, 302-2V, 3 on tree
- 72hiboy4x4
the solenoid is going out. 2 of my trucks do that same thing. but one of them was replaced 18 months ago for the same problem.
- jor
re: more gremlins
If it does the slow turnover thing when it is hot it may be the starter. Those of us with headers have a lot of experience with ruined starters. If you don't have headers then I would try Mohillbilly's suggestion and clean the starter post and also check the battery to engine ground.
jor
jor
- heep70
re: more gremlins
Its the fellow in the front of the truck with the crank handle. Give him a raise.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 19674x4
re: more gremlins
the electrical guy told me that the starter was going out, so that may be the problem, i'll try a spare solenoid i have.
My Photo Album
- 67highboy
re: more gremlins
Alot of times these old fords starters drag when they get hot.
Is it hot when it drags or cold?
also the timing being to far advancet will make the engine fight the starter
I dont know food for thought anyway...
John
John
Ben Franklin 1775
Ben Franklin 1775
- 19674x4
it does it when it's cold. the timing is set.
My Photo Album
- 67highboy
re: more gremlins
yes check your grounds then and I have also had trouble with the cable from the solenoid to the starter being blown up with corosion at the connector.
other that that I dont know
John
John
Ben Franklin 1775
Ben Franklin 1775
- wildcard
re: more gremlins
- 19674x4
sorry to bring up al old topic of mine but i replaced my brand new optima with another new one(thank god for a 3 year warranty) and i haven't had a problem, also my carb needs to be re-built.
My Photo Album
- 67highboy
