Cutting springs on a '70 F100
I have a 1970 F100 with a 302 (slight mods) 2 wheel drive. I am extremely interested in lowering the entire truck. However, my wife had a great idea; lower the front and leave the back stock height. That would make the truck look killer (lower in the front).
So my questions are:
1. If I want the front dropped 2", how many coils should I cut?
2. If I cut the springs, will it create any problems with the toe/tire wear?
3. Will I have to buy new radius arms, or anything, if I simply cut the springs?
4. Does anyone have a picture of a truck that has done what I am wanting to do (lower the front only)? If so, please provide pictures!
I am sure I will be posting a lot, when I start building up my new 302.
This site ROCKS!!!!
Thanks,
Kornhaus
This site ROCKS!!!!
Thanks,
Kornhaus
- Big D's 69
Talk to SmokeyBear about this. He seems to know a great deal about this.
- SmokeyBear
eh not true.layedout72 wrote:NEVER cut your springs, EVER.
they will not settle.
Every spring will settle, it depends on the amount of weight on it and what it was originally designed to do.
If you buy springs for a 460 and put them under a 6 banger, they won't settle much at all and be very stiff. But do the opposite and they will squat a LOT and be too soft.
What you want to do if you just want to go a couple of inches is cut a half a coil at a time then drive it for a week or so until you get what you want, if you cut too much at one time, then it's time to buy a new spring. It all depends on 1)how much weight is on your springs and 2)how much you cut them. Don't lower your truck more than 2 inches by cutting the coils(depending on how much your springs sag already) You'll run into a camber problem. If you want 3 inches or more, you need drop I-beams.
As far as leaving the back alone, it's all up to your preference but the back is a LOT easier to do than the front if that is what is holding you up. New drop-shackles will drop it 2 inches, flipping the hanger will lower it 3-5 inches depending on where you relocate it and an axle flip will lower it 4 or 5 but you'll have to notch your frame.
70 F-100 XLT
72 F-100 Ranger XLT
72 F-100 Ranger XLT
re: Cutting springs on a '70 F100
smokeybear,
All I want to do is drop the front about 2". The main reason I want to cut the springs, rather than buy the I-Beam kit, is price. If there is no harm in cutting the springs (1-1.5 coils) - which is FREE, why would I want to buy a $500 I-Beam lowering kit - that does the same thing (lower 2-3")?
I will not be doing any suspension mods for some time (probably not for another several months). Right now, I am just trying to gather as much information as I can, before I jump into anything.
Thank you all very much, for the fast and informative replies.
As I stated in my other post, I will be posting quite often, once I begin my rebuilding my suspension, engine, and everything else that comes along.
-Kornhaus
-Kornhaus
- SmokeyBear
I wont be doing this for some time. However, whenever I DO lower the truck, I will take pictures.
I am still debating on wheather I should just lower the entire truck, or just the front.
If I buy the I Beam drop kit (2-3"), how do I lower the back to match? Would I just buy the shackles or whatever? I don't want the back lower than the front, of course. I guess what I could do, is lower the back, buy the I beam drop kit, and then if the front is too high, I could just cut the springs a little couldn't I?
-Kornhaus
-Kornhaus
- SmokeyBear
- shortbedCUSTOM
hey SmokeyBear, where can I get a set of drop shackles, and how much should I expect to pay?
- SmokeyBear
Re: re: Cutting springs on a '70 F100
http://www.truckn-store.com/application_list.aspshortbedCUSTOM wrote:hey SmokeyBear, where can I get a set of drop shackles, and how much should I expect to pay?
or
http://www.djmsuspension.com/Products/P ... 0Parts.htm
somewhere around $70 to $85
70 F-100 XLT
72 F-100 Ranger XLT
72 F-100 Ranger XLT
- shortbedCUSTOM
- theskytoucher
- SmokeyBear
- theskytoucher
- Big D's 69
Just too many options on lowering these trucks. Can't wait to lower mine.
