my bed
edgar
my bed
Post by edgar »
my bed has a huge dent because someone hit and run my truck and it was parked on the side of my house. what process do i need to fix that big ass dent on the drivers side????
spartman
Post by spartman »
Put a big ass dent on the passenger side to match?
you can get replacment panels from lmc truck for the lower side of the bed.
edgar
re: my bed
Post by edgar »
the dent is bigger than that. you think i should heat it up and she if it start getting start when hit it then filler it in?
if its that big not to put a new bed side on it then youd be better off getting a new bed or take it to a body shop and at least get an estimate done.they may even tell you how to fix it.
67NC
Post by 67NC »
You can buy completly new bed side from National parts depot.com
72hiboy4x4
Post by 72hiboy4x4 »
put a big ass dent in the guy that put the dent in your truck!
460 crew
Post by 460 crew »
Just finish beating it in and make yourself a stepside?
post a pic of it.
studdmstr
Re: re: my bed
Post by studdmstr »
edgar wrote:the dent is bigger than that. you think i should heat it up and she if it start getting start when hit it then filler it in?
Say what?
rjewkes
Post by rjewkes »
whoa slow down wheres the Fire?
Ok first NPD has sides that are Made from A mold taken of the entire side of the truck. This will look horible.
where is the dent? If it is low enough you may be able to bring it almost flush. Get rid of the high spots with some grinding and use a thin layer of bondo. Chjeck witha parts house, O'reily, Kragens, Napa or even Autozone. They might have a manual based on auto body repair.
fuelly.com
