P/S Pump Pully
Hawkrod
Re: P/S Pump Pully
Post by Hawkrod »
390F100 wrote:Hawkrod,
I went to the bone yard and found a bracket for the ps pump but the one I found was for a 390 w/ ac and mine does not have air. the pump bolts up fine to the bracket but I dont know if it will cause the pully to be misaligned. I did thread a pulley on it and unfortunately it does not line up with everything else. I will end up needing the pulley and any other advise you may have. Thanks again :thup:
390
If you got the sheet steel bracket from a 70 and later 390 they are the same with or without AC. Trucks without AC just use a thick spacer behind the bracket where it bolts to the head. What is the number on the pulley you got? Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
390F100
Re: P/S Pump Pully
Post by 390F100 »
Looks like the pulley has an (A8) stamped in it and the bracket was from a 70 I believe but I do not have any spacer for the head. I bolted it up to the head and it seemed fine but what do I know... :hmm:
390
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
Re: P/S Pump Pully
you can use washers to space the bracket out to where it should be. i now seem to remember my dad doing that once.
Hawkrod
Re: P/S Pump Pully
Post by Hawkrod »
390F100 wrote:Looks like the pulley has an (A8) stamped in it and the bracket was from a 70 I believe but I do not have any spacer for the head. I bolted it up to the head and it seemed fine but what do I know... :hmm:
390
Take some pictures and show us what you have. A8 is not the number I am looking for so look again and find all of the numbers as there will be more. Hawkrod
This is what a 70 PS pump bracket and 6AA pulley should look like:
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
