Bad alignment problems
70_F100
Re: Bad alignment problems
Post by 70_F100 »
390Nut wrote: It also looks like you are missing your steering stops in the i-beams (the hole in the beam in that last pic)
Paul, wake up, buddy!!! The steering stops are cast into the I-beams and spindles. But you already knew that, I'm sure!!! :D
Notice on the right side, there is a lot of rust around the thrust bearing under the I-beam. That's a good indicator that the bearing is shot. :cry:
On the left side, there appears to be a pretty big gap on the top side of the I-beam, and the bearing on the lower side appears to be somewhat crushed. :doh:
There's no doubt in my mind that it's time to replace the kingpins (and associated parts). Until you do that, any other repairs will be futile. :2cents:
390Nut
Post by 390Nut »
yeah, brainfart on my part. :doh:
Paul
`69 F100 390 4spd driver
