Bendix Vs. Ford
69rangerf100
Re: Bendix Vs. Ford
Post by 69rangerf100 »
ok thanks for clarifying that so i guess i need to go and grab the pitman arm just to be safe for my disk conversion
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
bmerkley58
Re: Bendix Vs. Ford
Post by bmerkley58 »
The manual steering box pitman arm won't fit the Ford power steering box. The splined hole in the manual pitman arm is too small.
Bob
390F100
Re: Bendix Vs. Ford
Post by 390F100 »
I think I know what i'm gonna do, I went on www.carsteering.com and they have a conversion kit which includes the box,pump,coupler,hoses,pully...everything except the correct column. It runs 495.00. I think i'm goingto buy that and then get another column. what do you all think, heres the link
http://www.carsteering.com/addtocart/19 ... 80002.html
390
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
swinn
Re: Bendix Vs. Ford
Post by swinn »
I wasn't aware of the overheating problem with the bendix box. I just had mine rebuilt to fix the leaking. :eek: Would putting a small tranny cooler in the return line help at all, or is there some reason I shouldn't do that?
Scott
68 F250 CS LWB
390FE, C6
Re: Bendix Vs. Ford
yes the newer trucks had a power steerign cooler in line withhtem. they bolted to the front of the power steering pump brackt. that may help it from overheating.
swinn
Re: Bendix Vs. Ford
Post by swinn »
So what are the symptoms/problems that the overheating causes with the bendix box?
Scott
68 F250 CS LWB
390FE, C6
Re: Bendix Vs. Ford
i've never experience this. i did have a pump freeze up once on mine. but when i took it apart it became unfrozen. i never got around to putting it back on before i stopped driving the truck. but the box worked fine without the pump on it. it was harder to turn without the pump.
390bump
Re: Bendix Vs. Ford
Post by 390bump »
Anyone try the manual steering Pitman arm on a Bendix box?
Re: Bendix Vs. Ford
i looked one earlier the part number was C7TA-3590-M
390bump
Re: Bendix Vs. Ford
Post by 390bump »
manual should be -C or -N as per:
http://www.fordification.com/partnos/st ... column.htm
may try it myself this morning ( have the -N on my old box).
Re: Bendix Vs. Ford
it must have been a n then. i know it wasnt L
390bump
Re: Bendix Vs. Ford
Post by 390bump »
Dan is sending me another -L... the saga continues.
flakos 69
Re: Bendix Vs. Ford
Post by flakos 69 »
didn't ford change the steering linkage and pitman arm in 71, so he would need matching combo because the bendix only fit pre 71 asuming this he has a pre 71 steering linkage.
flakos 69
Re: Bendix Vs. Ford
Post by flakos 69 »
D2TA-3590-BA is a 72 part and this article covers that
http://www.fordification.com/tech/discbrakes01.htm
flakos 69
Re: Bendix Vs. Ford
Post by flakos 69 »
just my 2 cents correct me if im wrong
