Bendix Vs. Ford
- 69rangerf100
Re: Bendix Vs. Ford
ok thanks for clarifying that so i guess i need to go and grab the pitman arm just to be safe for my disk conversion
David
Re: Bendix Vs. Ford
The manual steering box pitman arm won't fit the Ford power steering box. The splined hole in the manual pitman arm is too small.
Bob
Bob
- 390F100
Re: Bendix Vs. Ford
I think I know what i'm gonna do, I went on www.carsteering.com and they have a conversion kit which includes the box,pump,coupler,hoses,pully...everything except the correct column. It runs 495.00. I think i'm goingto buy that and then get another column. what do you all think, heres the link
http://www.carsteering.com/addtocart/19 ... 80002.html
390
390
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
Re: Bendix Vs. Ford
I wasn't aware of the overheating problem with the bendix box. I just had mine rebuilt to fix the leaking.
Would putting a small tranny cooler in the return line help at all, or is there some reason I shouldn't do that?
Scott
68 F250 CS LWB
390FE, C6
68 F250 CS LWB
390FE, C6
Re: Bendix Vs. Ford
yes the newer trucks had a power steerign cooler in line withhtem. they bolted to the front of the power steering pump brackt. that may help it from overheating.
Re: Bendix Vs. Ford
So what are the symptoms/problems that the overheating causes with the bendix box?
Scott
68 F250 CS LWB
390FE, C6
68 F250 CS LWB
390FE, C6
Re: Bendix Vs. Ford
i've never experience this. i did have a pump freeze up once on mine. but when i took it apart it became unfrozen. i never got around to putting it back on before i stopped driving the truck. but the box worked fine without the pump on it. it was harder to turn without the pump.
- 390bump
Re: Bendix Vs. Ford
Anyone try the manual steering Pitman arm on a Bendix box?
- 390bump
Re: Bendix Vs. Ford
manual should be -C or -N as per:
http://www.fordification.com/partnos/st ... column.htm
may try it myself this morning ( have the -N on my old box).
- 390bump
Re: Bendix Vs. Ford
Dan is sending me another -L... the saga continues.
Re: Bendix Vs. Ford
didn't ford change the steering linkage and pitman arm in 71, so he would need matching combo because the bendix only fit pre 71 asuming this he has a pre 71 steering linkage.
Re: Bendix Vs. Ford
D2TA-3590-BA is a 72 part and this article covers that
http://www.fordification.com/tech/discbrakes01.htm
Re: Bendix Vs. Ford
just my 2 cents correct me if im wrong
