New from MO-Updated with pictures
- cathynkeith
re: New from MO
Welcome
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
- jbanks
re: New from MO
A big Texas to you. And to answer your question, the whole grille setup will interchange. If you're just wanting to swap inserts they will work but I believe you need to do some modifying as the inserts mount in different locations between a 70 and a 72 grille.
- 67F250CS
re: New from MO
Howdy from Kansas
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
- 4x4x4crewcab
re: New from MO
Welcome Great story thanks for sharing. The 71-72 inserts each have 6 mounting screw locations(4 the same 2 different depths). The 70 inserts each have 4 mounting screw locations(all the same depth)
71-72 2 top,2 bottom, 1 on each side middle
70 has 2 top and 2 bottom but none on the side middle
now for the bad news If I recall correctly the top and bottom locations are all in the same locations but the 71-72 grille shell will have 2 of the 4 mounting screw locations (on each side) offset deeper (I believe the bottom 2). Clear as mud
There are pictures on the site somewhere showing the differences
Enjoy the site
Enjoy the site
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
1999 Ford Windstar
re: New from MO
Update-here are some pics. I plan on bringing it home this week. I'm just trying to decide if I want to make a 4-wheel drive out of it, or leave it a 2 wheel drive. The rust shown in the pics is surface rust believe it or not. [/img]
re: New from MO-Updated with pictures
Looks good!!! Another bump saved!! I would leave it a 2 wd, and find a 4x4 bump. Get on that rust, I am sure it has some nice pitting. My hood looks like that on the under side. Sweet enjoy the ride!!
- MadMaxetc
Welcome!
that looks ike a good project. Take your time and do it right!
If you are not sure what you want...start writing it all down on a peice of paper. It realy helps develope a plan. you will start to see what will work and what will not right away.
good luck!
good luck!
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- mrung0wa
Welcome my FORDification Brother!
You'll find that this is the best place where the best people hang out!
Like I always say "This place is better than Disneyland!"
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
