New from MO-Updated with pictures
cathynkeith
re: New from MO
Post by cathynkeith »
Welcome :D
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
jbanks
re: New from MO
Post by jbanks »
A big Texas :wel: to you. And to answer your question, the whole grille setup will interchange. If you're just wanting to swap inserts they will work but I believe you need to do some modifying as the inserts mount in different locations between a 70 and a 72 grille. :thup:
67F250CS
re: New from MO
Post by 67F250CS »
Howdy from Kansas :D
1967 F250 Camper Special
4x4x4crewcab
re: New from MO
Post by 4x4x4crewcab »
Welcome Great story thanks for sharing. The 71-72 inserts each have 6 mounting screw locations(4 the same 2 different depths). The 70 inserts each have 4 mounting screw locations(all the same depth)
71-72 2 top,2 bottom, 1 on each side middle
70 has 2 top and 2 bottom but none on the side middle
now for the bad news If I recall correctly the top and bottom locations are all in the same locations but the 71-72 grille shell will have 2 of the 4 mounting screw locations (on each side) offset deeper (I believe the bottom 2). Clear as mud :?
There are pictures on the site somewhere showing the differences
Enjoy the site
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
mo-bronco
re: New from MO
Post by mo-bronco »
Update-here are some pics. I plan on bringing it home this week. I'm just trying to decide if I want to make a 4-wheel drive out of it, or leave it a 2 wheel drive. The rust shown in the pics is surface rust believe it or not. [/img]
mljjones67
re: New from MO-Updated with pictures
Post by mljjones67 »
Looks good!!! Another bump saved!! I would leave it a 2 wd, and find a 4x4 bump. Get on that rust, I am sure it has some nice pitting. My hood looks like that on the under side. Sweet enjoy the ride!! :thup:
MadMaxetc
Post by MadMaxetc »
Welcome!
that looks ike a good project. Take your time and do it right!
If you are not sure what you want...start writing it all down on a peice of paper. It realy helps develope a plan. you will start to see what will work and what will not right away.
good luck!
Dan
FORD Girl
Photobucket Pictures
Brett6269
Post by Brett6269 »
:thup: :wel:
lover of old fords
mrung0wa
Post by mrung0wa »
:wel: :fr: :clap: :yt: 8) :hi: :wel:
Welcome my FORDification Brother!
You'll find that this is the best place where the best people hang out!
Like I always say "This place is better than Disneyland!"
Lawrence Image
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
